[mapguide-users] Getting started using Visual Studio 2005
Tsai Chih-Cheng cctsai82 at gmail.com
Sun Jul 1 15:26:29 EDT 2007
Hi:
According to my experience, you can check if you can run the offical sample
: dotnetviewersample-1.1.zip<http://download.osgeo.org/mapguide/releases/1.1.0/samples/dotnetviewersample-1.1.zip>referred
to Installing
the MapGuide Sample Data and
Application<http://mapguide.osgeo.org/files/mapguide/docs/InstallMapGuideOpenSourceSamples.pdf>
If it goes fine, I think you could develop your AP easily.
Patrick
On 7/2/07, Johannes Elsinghorst <JohannesElsinghorst at gmx.net> wrote:
> Hi,
> im trying to get into he developement of mapguide-webapps using VS2005
> and asp.net.
> I set up a new Webproject and added a reference to MapGuideDotNetApi.dll
> and also copied
> all the dlls from the dotnetviewer into my webapps bin folder.
> In the load-event of my default.aspx i added the following code:
> protected void Page_Load(object sender, EventArgs e)
>             try
> MapGuideApi.MgInitializeWebTier
> (@"C:/Programme/MapGuideOpenSource/WebServerExtensions/www/webconfig.ini");
>             catch (Exception ex)
>                 System.Diagnostics.Debug.WriteLine(ex.Message + "\n" +
> ex.StackTrace);
>             MgUserInformation userInfo = new
> MgUserInformation("Anonymous", "");
>             MgSite site = new MgSite();
>             site.Open(userInfo);
>             sessionId = site.CreateSession();
>                 int debug=0;
> MgInitializeWebTier-Method throws this Exception:
> [DllNotFoundException: Unable to load DLL 'MapGuideUnmanagedApi': Das
> angegebene Modul wurde nicht gefunden. (Exception from HRESULT: 0x8007007E)]
>    SWIGExceptionHelper.SWIGRegisterCustomExceptionCallbacks_MapGuideApi(SWIGCustomExceptionDelegate
> customExceptionDelegate) +0
>    SWIGExceptionHelper..cctor() +70
> [TypeInitializationException: The type initializer for
> 'SWIGExceptionHelper' threw an exception.]
>    SWIGExceptionHelper..ctor() +0
>    MapGuideApiPINVOKE..cctor() +60
> 'MapGuideApiPINVOKE' threw an exception.]
>    MapGuideApiPINVOKE.new_MgUserInformation__SWIG_2(String jarg1, String
> jarg2) +0
>    OSGeo.MapGuide.MgUserInformation..ctor(String userName, String
> password) +34
>    MapGuideTest1._Default.Page_Load(Object sender, EventArgs e) in
> C:\Dokumente und Einstellungen\JMan\Eigene Dateien\Visual Studio
> 2005\Projects\MapGuideTest1\MapGuideTest1\Default.aspx.cs:32
>    System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o,
> Object t, EventArgs e) +15
>    System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender,
> EventArgs e) +34
>    System.Web.UI.Control.OnLoad(EventArgs e) +99
>    System.Web.UI.Control.LoadRecursive() +47
>    System.Web.UI.Page.ProcessRequestMain(Boolean
> includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +106
> Has anybody an idea what to do about it?
> thanks, Johannes
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070702/90188f31/attachment.html
