[mapguide-users] Installation assistance
zorou zoroufatal at gmail.com
Sat Jul 14 20:44:11 EDT 2007
Hi,folker,I've faced the same problem as you.
And i solved it.
The way is as below
1.Find the php.ini file in your webserverextension folder (sth like
C:\Program Files\MapGuideOpenSource\WebServerExtensions\Php\php.ini)
2.Simply copy this file to your c:\php\ to overwrite your php.ini(if your
original php.ini exsits there)
3.I know you've got some other php projects running on the same IIS.So ,just
compare the two files and copy what you need from the php.ini in the
webserverextension folder to your original file.
I'm sure you will find it working~ Good luck,man.
David Nuell wrote:
> Hi Listers -
> Here is the scoop.  I am running a Windows 2003 Server with IIS6 and PHP
> 5.2.1 (no apache, no tomcat).  I have a wiki set up for our company that
> uses the PHP 5.2.1 (successfully).  I have read on the 1.2.0RC2 download
> site that PHP5.2.1 should work with this version.
> I have installed 1.2.0RC2 onto the server and have gone through the
> install document (Installing and Configuring on Windows).  I have set
> all relevant PHP look ups from the MapGuideOpenSource directory to the
> location on the server where I installed PHP 5.2.1 (i.e., C:\PHP\).
> After installation, I get the following:
> Testing Map Agent: the XML Document shows
> Testing Site Administrator: The log in screen shows.  I input
> Administrator and admin as the L/P and the next screen shows up blank.
> The source code for the page is also blank.
> Testing Web Server Extensions: The page can not be found.
> I have been reading through the archives for similar issues and have
> read relevant posts.  Nothing has yet been the answer to my issue stated
> above.  Can someone out there lend me their expert advice?  I would be
> greatly appreciative.
> David
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
^L^^L^
View this message in context: http://www.nabble.com/Installation-assistance-tf4063647s16610.html#a11598648
