[mapguide-users] Error with GD2.0.33 building Mapguide
Ray Holtz ray at rayholtz.com
Wed Jul 25 00:27:18 EDT 2007
Frank, thank you, that got me past that bit of nastyness, onto the next!
I ran ./build_oem.sh again and it got further, and stopped here:
I'm not sure what it is telling me to do, how do I recreate aclocal.m4
with aclocal?
Thanks!
** Configuration summary for gd 2.0.33:
    Support for PNG library:          yes
    Support for JPEG library:         yes
    Support for Freetype 2.x library: yes
    Support for Fontconfig library:   no
    Support for Xpm library:          no
    Support for pthreads:             yes
configure: creating ./config.status
config.status: creating Makefile
config.status: creating config/Makefile
config.status: creating config/gdlib-config
config.status: creating test/Makefile
config.status: creating config.h
config.status: config.h is unchanged
config.status: executing depfiles commands
  cd . && /bin/sh /usr/local/maptemp/mapguide/Oem/gd/gd/config/missing
--run automake-1.9 --foreign
configure.ac:27: version mismatch.  This is Automake 1.9.6,
configure.ac:27: but the definition used by this AM_INIT_AUTOMAKE
configure.ac:27: comes from Automake 1.9.2.  You should recreate
configure.ac:27: aclocal.m4 with aclocal and run automake again.
make: *** [Makefile.in] Error 1
GD 2.0.33: Error build failed (0).................
[root at WebServer mapguide]#
Frank Warmerdam wrote:
> Ray Holtz wrote:
>> Hey all, Everytime I make a bit of headway, I just get stuck again.  I
>> am following the directions on
>> http://wiki.osgeo.org/index.php/Building_MapGuide_on_Fedora_Core_6 to
>> build Mapguide on FC6.  I have finished the mapguideaptinstaller,
>> gotten past the FDO install, now I am running ./build_oem.sh for
>> mapguide.  I completed the first and second error-fixes, and how am
>> getting stuck again.  These are the last 30ish lines that I get.  Can
>> anyone look at this and point me in the right direction to get past
>> this error?
>> Thanks a lot!!  I appreciate all the help everyone has already given me!
> Ray,
> Where ever the configure is done for GDAL, try adding --without-python
> to the
> configure line.
> Best regards,
