[mapguide-users] Selection problem with map stored in session repository
Ismael Cams mapguide2007 at gmail.com
Thu Jul 26 10:51:38 EDT 2007
Thanks for the answer Kenneth.
I have checked the coordinates and they are indeed skewed. The x coordinates
are ok, but the y coordinates do not match (which explains why I have to
click somewhat above the point in order to select it). As soon as I resize
the legend frame the coordinates get ok.
The MCS part is not clear to me. Can I somehow make changes to this
functions in order to solve the problem or can I try something else (without
having to disable my legend) ?
For your notice: I make also selections programatically. This works fine in
all cases.
Kenneth, GEOGRAF A/S wrote:
> I would say that the offset is likely caused by something incorrect on
> the html side.
> If point 7 means: create 2 layouts in studio and test them in the same
> app,
> it would appear that a setting in the WebLayout file causes the html to
> report bad map offsets.
> You might see the actual coordinats being sent, by inserting an
> "alert(...)" in ajaxmappane.templ,
> where it builds the polygon (search for "POLYGON").
> If the coordinates are correct (ea. the same), I have no clue.
> If the coordinates are skewed, look in the ajaxmappane.templ,
> for the function that calculates the MCS coordinates from screen (x,y).
> That functions has some offsets, and it is my guess that they slip a bit.
> Regards, Kenneth, GEOGRAF A/S
> Ismael Cams skrev:
>> I have following situation:
>> 1. I build dynamically two weblayouts in a session. One is containing a
>> legend, the other one is only containing the zoom control.
>> 2. The weblayouts refer to the same mapdefinition that is also build in a
>> session.
>> 3. The mapdefinition is referring to a point layer (sessionlayer)
>> 4. Making a selection in the weblayout without legend works fine.
>> 5. Making a selection in the weblayout with legend does not work
>> correctly.
>> I have to click above the point to actually make the selection.
>> 6. When I minimize the legend frame (by using the arrow in the
>> webbrowser)
>> the selection suddenly works correctly. Also when I disable the legend in
>> the first layout this is also working fine.
>> 7. When I create the same scenario with Studio I do not encounter the
>> problem (selection is working without problems).
>> I believe it has something to do with using the same session, but I do
>> not
>> have a clue where to look after. Can someone give me hints about what
>> could
>> be the problem ?
>> Kind regards,
>> Ismaël
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Selection-problem-with-map-stored-in-session-repository-tf4151469s16610.html#a11812151
