[mapguide-users] Problem with legend - style
Kenneth, GEOGRAF A/S ks at geograf.dk
Mon Jun 4 06:08:33 EDT 2007
That probably means that the document you upload does not validate
according to the XSD schema.
You can find the XSD Schema's in the "Schema" folder where you installed
MapGuide.
There are free xml validators on the web, that will give you more detail
on what went wrong.
Be aware that there is a different schema for each resource type.
Also, you MUST use UTF-8 encoding (it will not give the above error, but
won't display the map).
Regards, Kenneth, GEOGRAF A/S
martijni wrote:
> James,
> I doubt that I misstyped the resource ID, because I tried different resource
> ID's to make sure it wasn't a typo. Each time I receive this exception:
> An exception occurred in the XML parser.
> An exception occurred in the XML parser. Exception occurred in method
> MgResourceContentManager.ValidateDocument at line 586 in file
> c:\build_bond_area\mapguide_open_source\build_3.1\mgdev\server\src\services\resource\ResourceContentManager.cpp
> Don't know if this gives you some more information...?
> James Card wrote:
>> On Fri, 01 Jun 2007 06:48:01 -0700, martijni <mis at gemeentehulst.nl> wrote:
>>> I understand what you say, but do I have to reload the XML using the
>>> mapagent interface like this way:
>>> Resource --> SetResource --> Resource ID is location where the file will
>>> be placed
>>> Content is the location of the xml file
>>> Header is empty
>>> But when I did it this way I received an exception. Is this the way you
>>> should do it, or did you mean something else?
>> That is exactly the procedure we use here. Did you mistype the Resource
>> ID? Is your XML file valid?
>> James Card
>> California CAD Solutions, Inc.
>> 209 578-5580
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070604/a6f6b9cf/attachment.html
