[mapguide-users] Problem with legend - style
martijni mis at gemeentehulst.nl
Mon Jun 4 02:37:08 EDT 2007
I doubt that I misstyped the resource ID, because I tried different resource
ID's to make sure it wasn't a typo. Each time I receive this exception:
An exception occurred in the XML parser.
An exception occurred in the XML parser. Exception occurred in method
MgResourceContentManager.ValidateDocument at line 586 in file
Don't know if this gives you some more information...?
James Card wrote:
> On Fri, 01 Jun 2007 06:48:01 -0700, martijni <mis at gemeentehulst.nl> wrote:
>> I understand what you say, but do I have to reload the XML using the
>> mapagent interface like this way:
>> Resource --> SetResource --> Resource ID is location where the file will
>> be placed
>> Content is the location of the xml file
>> Header is empty
>> But when I did it this way I received an exception. Is this the way you
>> should do it, or did you mean something else?
> That is exactly the procedure we use here. Did you mistype the Resource
> ID? Is your XML file valid?
> James Card
> California CAD Solutions, Inc.
> 209 578-5580
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Problem-with-legend---style-tf3847021s16610.html#a10944506
