[mapguide-users] postgis fdo-ogr and spatial indexes
alucas alucas at srtec.com
Wed Jun 13 17:48:25 EDT 2007
Where can I download the source code of ogr provider?
Frank Warmerdam-2 wrote:
> alucas wrote:
>> Hello,
>> I'm testing the ogr provider with postgis and it works fine, I connect
>> vía
>> Map 2008 and MGOS 1.2. So, the question is about the spatial indexes
>> (gist).
>> How works the ogr provider with gist indexes? I'm attempting to get
>> better
>> performance with this configuration.
> "alucas",
> GDAL/OGR 1.4 uses the following construct when building a
> query against a postgis table to apply a spatial filter.
>      m_poFilterGeom->getEnvelope( &sEnvelope );
>          osWHERE.Printf("WHERE %s && SetSRID('BOX3D(%.12f %.12f, %.12f
> %.12f)'::box3d,%d) ",
>                         pszGeomColumn,
>                         sEnvelope.MinX, sEnvelope.MinY,
>                         sEnvelope.MaxX, sEnvelope.MaxY,
>                         nSRSId );
> This is intended to use the spatial index and normally works as
> far as I know.  If you run MgServer from the commandline, and
> enable CPL_DEBUG (set this enviroment variable to ON) you should
> see debug output from the OGR provider indicating the specific query
> it ends up using.  It should be prefixed with something like:
>    OGRPGTableLayer::BuildWhere returns:
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | President OSGeo, http://osgeo.org
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/postgis-fdo-ogr-and-spatial-indexes-tf3917522s16610.html#a11109589
