[mapguide-users] Bad labels
Jon Rizzo jrizzo at Langan.com
Mon Jun 18 15:55:29 EDT 2007
This same behavior exists in RC2.  This problem did not exist in 1.1.0
Jon Rizzo wrote:
> I noticed that in 1.2 RC1, labels are occasionally not displayed properly.
> I have posted two images - they are the same label displayed at different
> scales.  I have attached two images.  bad.jpg shows the incorrect labels
> and good.jpg shows the correct labels.  I'm not sure where those numbers
> came from, but the feature does not have any attributes with values like
> that.  There is not a corresponding scale range in the layer definition,
> so the two layers should be identical.  This did not happen in 1.1.
> bad:
>  http://www.nabble.com/file/p11102528/bad.jpg
> good:
>  http://www.nabble.com/file/p11102528/good.jpg
View this message in context: http://www.nabble.com/Bad-labels-tf3915608s16610.html#a11182905
