[mapguide-users] Problem installing MGOS 1.2
Kenneth, GEOGRAF A/S ks at geograf.dk
Tue Jun 26 08:33:41 EDT 2007
I have seen the message "The specified module could not be found" in
other situations.
It is usually a problem with a missing Dll.
You can use a tool called "Dependency Walker" to troubleshoot problems
(drag the file in question into DW).
You description makes me belive that the problem is either with
fcgi_isapi.dll or mapagent.exe, both in the WebTier folder.
You can also try "uninstall" and then remove the entire
"MapGuideOpenSource" folder (remember to back up any repositiories first!).
A fresh install should make everything work out fine.
Regards, Kenneth, GEOGRAF A/S
Stefan Dalakov skrev:
> Hi all,
> I wanted to move to MGOS 1.2 after using MGOS 1.1 for some time.
> I removed ( reinstalled ) the previous installation but I can't make
> this work. Tried installing again and again for 10-15 times but no
> success.
> I can access mapadmin module - it works ok, and reports that the
> server is ON. The installation module did not create php association
> but I fixed this.
> When I send requests like
> http://localhost/mapguide/mapagent/mapagent.fcgi?OPERATION=ENUMERATERESOURCES&VERSION=1.0.0&LOCALE=en&RESOURCEID=Library://&TYPE=&DEPTH=-1
> I get message "The specified module could not be found"
> If I open http://localhost/mapguide/mapagent/index.html - Web Tier
> Tests it fails everywhere (same message), except for the "Server admin
> services"
> I checked the .fcgi association about 15 times - it seems OK.
> Mapguide Studio also reports "fail due to unknown reason"
> I am running WIN XP SP2, with IIS, using PHP as dev. environment.
> Any suggestions ?
> Thanks in advance
> Stefan Dalakov
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
