[mapguide-users] Problem installing MGOS 1.2
Stefan Dalakov s.dalakov at mapware.net
Fri Jun 29 00:43:57 EDT 2007
I am posting this back, as some one else might suffer from the same.
Traian was right.
 So, to make the long story short, the MGOS 1.1 uninstall process leaves
too many registry entries after itself, which somehow "confuses" MGOS
1.2. As a result, strange false errors appear. I've seen also a
"connection problem" message. The problem is resolved by using a tool
which ensures complete uninstall - there are many like this around.
After that everything works fine.
Regards : Stefan
Traian Stanev wrote:
> I think this is a false error, I see depends.exe complain about that
> file all the time when it's not really a problem. It must be something
> else that is causing your problem.
> Traian
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Stefan
> Dalakov
> Sent: Tuesday, June 26, 2007 10:12 AM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] Problem installing MGOS 1.2
> Dependency walker reports about DWMAPI.DLL missing.
> Where can I get this file from ?
> Regards : Stefan
> Kenneth, GEOGRAF A/S wrote:
>> I have seen the message "The specified module could not be found" in
>> other situations.
>> It is usually a problem with a missing Dll.
>> You can use a tool called "Dependency Walker" to troubleshoot problems
>> (drag the file in question into DW).
>> You description makes me belive that the problem is either with
>> fcgi_isapi.dll or mapagent.exe, both in the WebTier folder.
>> You can also try "uninstall" and then remove the entire
>> "MapGuideOpenSource" folder (remember to back up any repositiories
>> first!).
>> A fresh install should make everything work out fine.
>> Regards, Kenneth, GEOGRAF A/S
>> Stefan Dalakov skrev:
>>> Hi all,
>>> I wanted to move to MGOS 1.2 after using MGOS 1.1 for some time.
>>> I removed ( reinstalled ) the previous installation but I can't make
>>> this work. Tried installing again and again for 10-15 times but no
>>> success.
>>> I can access mapadmin module - it works ok, and reports that the
>>> server is ON. The installation module did not create php association
>>> but I fixed this.
>>> When I send requests like
> http://localhost/mapguide/mapagent/mapagent.fcgi?OPERATION=ENUMERATERESO
> URCES&VERSION=1.0.0&LOCALE=en&RESOURCEID=Library://&TYPE=&DEPTH=-1
>>> I get message "The specified module could not be found"
>>> If I open http://localhost/mapguide/mapagent/index.html - Web Tier
>>> Tests it fails everywhere (same message), except for the "Server
>>> admin services"
>>> I checked the .fcgi association about 15 times - it seems OK.
>>> Mapguide Studio also reports "fail due to unknown reason"
>>> I am running WIN XP SP2, with IIS, using PHP as dev. environment.
>>> Any suggestions ?
>>> Thanks in advance
>>> Stefan Dalakov
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070629/8863243c/attachment.html
