[mapguide-users] Mg build error on Ubuntu 6.10
Jo Cook j.cook at OXFORDARCH.CO.UK
Tue Mar 6 09:26:39 EST 2007
I'd just like to chime in at this point and say that I am also trying to get
Mapguide 1.1.0 working on Ubuntu, though I'm using 6.06. After many attempts
I got it to configure and install all the additional components, but have
tried and failed to get the main build to work. I did post to the list about
this a few weeks ago, so do a search for Ubuntu and you'll find my post.
I could perhaps let you know which additional libraries I had to install to
get past the build_oem.sh stage- I didn't have to make any changes to the
code. Unfortunately I am still stuck at the final hurdle. I have also tried
to install Mapguide 1.0.2 working, but that failed at an earlier stage.
If you need me to figure out which libraries I had to install, then let me
know and I fill try and get them from my notes. I am going to try the
installation on Ubuntu 6.10, to see if it fails at the same place...
Jo
François Van Der Biest wrote:
> Hi list,
> I'm trying to build Mg 1.1 on a Ubuntu 6.10 system
> At the build_oem.sh step, compilation stops because of a switch that
> seems to be interpreted as a command : -avoid-version (see log below)
> I've been looking in the different Makefiles if I could spot a typo,
> without success.
> Any idea ?
> F.
> make  all-recursive
> make[1]: entrant dans le répertoire «
> /home/vdb/Projets/MapGuide/mapguide-1.1.0/Oem/DWFTK7.1/develop/global/src/dwf
> Making all in package
> make[2]: entrant dans le répertoire «
> /home/vdb/Projets/MapGuide/mapguide-1.1.0/Oem/DWFTK7.1/develop/global/src/dwf/package
> Making all in reader
> make[3]: entrant dans le répertoire «
> /home/vdb/Projets/MapGuide/mapguide-1.1.0/Oem/DWFTK7.1/develop/global/src/dwf/package/reader
> make[3]: Rien à faire pour « all ».
> make[3]: quittant le répertoire «
> Making all in writer
> /home/vdb/Projets/MapGuide/mapguide-1.1.0/Oem/DWFTK7.1/develop/global/src/dwf/package/writer
> Making all in extensions
> make[4]: entrant dans le répertoire «
> /home/vdb/Projets/MapGuide/mapguide-1.1.0/Oem/DWFTK7.1/develop/global/src/dwf/package/writer/extensions
> Making all in 6.01
> make[5]: entrant dans le répertoire «
> /home/vdb/Projets/MapGuide/mapguide-1.1.0/Oem/DWFTK7.1/develop/global/src/dwf/package/writer/extensions/6.01
> make[5]: Rien à faire pour « all ».
> make[5]: quittant le répertoire «
> Making all in 6.0
> avoid-version
> ../../../package/writer/extensions/6.01/libdwfpackagewriterextensions601.la
> ../../../package/writer/extensions/6.0/libdwfpackagewriterextensions60.la
> -lz
> make[5]: avoid-version : command not found
> make[5]: [libdwfpackagewriterextensions.la] Erreur 127 (ignorée)
> make[4]: quittant le répertoire «
> make[4]: *** Pas de règle pour fabriquer la cible «
> ../../package/writer/extensions/libdwfpackagewriterextensions.la »,
> nécessaire pour « libdwfpackagewriter.la »». Arrêt.
> make[3]: *** [all-recursive] Erreur 1
> make[2]: *** [all-recursive] Erreur 1
> make[2]: quittant le répertoire «
> make[1]: *** [all-recursive] Erreur 1
> make[1]: quittant le répertoire «
> make: *** [all-recursive-am] Erreur 2
> DWFTK 7.1: Error build failed (0).................
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Mg-build-error-on-Ubuntu-6.10-tf3334557s16610.html#a9332625
