[mapguide-users] Web Studio error
Jason Birch Jason.Birch at nanaimo.ca
Fri Mar 30 17:18:14 EDT 2007
It might be a PHP error.  It might also be an IIS setting.  It's hard to
tell :)
In your IIS admin console, do you have Web Service Extensions for
FastCGI and PHP configured and set to Allowed?
I'm about to do an install on a 2003 SP2 (not R2) server; I'll be able
to help more once this is done.
I have to ask:  citycourtenay:  Courtenay BC?
Jason
-----Original Message-----
Subject: [mapguide-users] Web Studio error
If I attempt :
http://localhost/mapguide/webstudio
I get the default webstudio ajax login dialog box with the user/pass
already filled it along with the above URL but when I try login I get a
IE dialog box stating " The URL you requested does not exist, please try
again"
running on IIS 6, windows 2003 std server sp 2, IE 6 Installed the .NET
web extentions and checked all the php settings with the manual,
although none of the PHP pages will display either, I get a "Page not
found". so it seems likely it is a php problem ?
