[mapguide-users] RE: Web Studio error
citycourtenay mwcourtenay at yahoo.com
Fri Mar 30 18:00:19 EDT 2007
Yes, It's probably a PHP error, I chose the default install for .NET and not
PHP but I quess PHP still gets installed in order to use the admin tools ?
The IIS Web server extentions are in place, and set for "allowed" .
I'm curious to hear how your install goes.
Yes Courtenay, B.C. (I think I might change that name :)
JasonBirch wrote:
> It might be a PHP error.  It might also be an IIS setting.  It's hard to
> tell :)
> In your IIS admin console, do you have Web Service Extensions for
> FastCGI and PHP configured and set to Allowed?
> I'm about to do an install on a 2003 SP2 (not R2) server; I'll be able
> to help more once this is done.
> I have to ask:  citycourtenay:  Courtenay BC?
> Jason
> -----Original Message-----
> From: citycourtenay
> Subject: [mapguide-users] Web Studio error
> If I attempt :
> http://localhost/mapguide/webstudio
> I get the default webstudio ajax login dialog box with the user/pass
> already filled it along with the above URL but when I try login I get a
> IE dialog box stating " The URL you requested does not exist, please try
> again"
> running on IIS 6, windows 2003 std server sp 2, IE 6 Installed the .NET
> web extentions and checked all the php settings with the manual,
> although none of the PHP pages will display either, I get a "Page not
> found". so it seems likely it is a php problem ?
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Web-Studio-error-tf3494506s16610.html#a9761700
