[mapguide-users] Use Group By or Distinct Query in MapGuideApplication
Dave Wilson dave.wilson at autodesk.com
Wed May 2 10:13:42 EDT 2007
In order to determine if Distinct is supported you need to check the
provider capabilities via the Web Tier API test pages.
http://servername/mapguide/mapagent/index.php
Select Feature from the list then select GetCapabilities and enter the
provider you are using.
Each provider has it's own supported list of operations and functions.
Regards,
Dave
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dhirendra
Kumar
Sent: Tuesday, May 01, 2007 11:07 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Use Group By or Distinct Query in
MapGuideApplication
Hi All,
In my SDF file's have some Duplicate rows and when i fetch data using
query then it return all duplicate rows also, but i want to fetch only
one copy of Duplicate rows. when i use distinct or group by clause then
it is not working and not return proper result. So, is it possible to
use Group By or Distinct clause with MGOS ?, If yes then how or any
alternate way ? Pls help me. Thankyou in Advance.
Regards,
Dhirendra Kumar
View this message in context:
http://www.nabble.com/Use-Group-By-or-Distinct-Query-in-MapGuide-Applica
tion-tf3678724s16610.html#a10280223
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
