[mapguide-users] RE: question Postgre Search tools php
Jason Birch Jason.Birch at nanaimo.ca
Tue May 8 16:50:45 EDT 2007
I don't have time to totally understand your code, but a couple things
come to mind like:
- the $filter needs to be a valid expression (like "clave = 3912")
- make sure that you have the right case for the column name.  FDO is
case-sensitive.
- not sure why you're opening the Map?
Jason
-----Original Message-----
Subject: [mapguide-users] RE: question Postgre Search tools php
'3912' is the echo from my filter
The specified object was not found.The specified object was not found.
Exception occurred in method GetItem at line 115 in file
.\Data\NamedCollection
