[mapguide-users] RE: RE: question Postgre Search tools php
MapasCatastro mapas at laplata.gov.ar
Wed May 9 07:08:48 EDT 2007
thanks  Jason
my question is this part the code is fine to read to postgre?
$featureResId = new
MgResourceIdentifier("Library://quilmes/postgre/conectancia.FeatureSource");
            $queryOptions = new MgFeatureQueryOptions();
            $queryOptions->SetFilter($filter);
            $geometryReaderWriter = new MgAgfReaderWriter();
            $featureReader = $featureService->SelectFeatures($featureResId,
"OGRSchema:callesnodos", $queryOptions);
            $featureReader->ReadNext();
            $name = $featureReader->GetString('clave');
            $byteReader = $featureReader->GetGeometry('the_geom');
thanks a lot
oscar
JasonBirch wrote:
> I don't have time to totally understand your code, but a couple things
> come to mind like:
> - the $filter needs to be a valid expression (like "clave = 3912")
> - make sure that you have the right case for the column name.  FDO is
> case-sensitive.
> - not sure why you're opening the Map?
> Jason
> -----Original Message-----
> From: MapasCatastro
> Subject: [mapguide-users] RE: question Postgre Search tools php
> '3912' is the echo from my filter
> The specified object was not found.The specified object was not found.
> Exception occurred in method GetItem at line 115 in file
> .\Data\NamedCollection
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/question-Postgre-Search-tools-php-tf3711540s16610.html#a10392277
