[mapguide-users] Tiled map using GETMAPIMAGE
Zac Spitzer zac.spitzer at gmail.com
Thu May 10 07:37:10 EDT 2007
i believe mapguide 1.20 allows configurable tile sizes
z
On 5/10/07, Brendan Cervin <bcervin at gmail.com> wrote:
> Hello velen,
> I stumbled across your mapguide-users enquiry regarding point labeling with
> GETMAPIMAGE. I have made a custom cache for use with my own interface, with
> the exact same problem.
> I wondered if you had a solution to this, or if you live with the problem
> like I do. Here are some thoughts of mine on a solution.
> Use the GETTILEIMAGE command, the drawbacks are, you are limited to
> mapguides positioning, and a hardcoded tile size of 300x300 (which is my
> tile size anyway). This is only available as a PNG as far as I know, which I
> don't like.
> The new 1.2 mapguide is supposed to have several improvements in this area,
> so that could be worth waiting for.
> I have tried playing with base layers to force nice labeling..
> unsuccessfully.
> I have made my image request to GETMAPIMAGE about 2000x2000 pixels to limit
> the occurance of this problem..
> If you have any thoughts on this, please get back to me.
> Cheers, Brendan.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer
+61 405 847 168
