[mapguide-users] OGR and MGOS
Traian Stanev traian.stanev at autodesk.com
Fri May 11 14:40:48 EDT 2007
In Studio, create a New Data Connection. It will show a list of
providers including the OGR provider. When you press on that, it will
bring up a connection editor dialog that lets you set the OGR connection
string. If the provider does not show up in the list, then it is not
installed correctly on the server.
Traian
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris
Gountanis
Sent: Friday, May 11, 2007 2:17 PM
To: 'MapGuide Users Mail List'
Subject: [mapguide-users] OGR and MGOS
I have used the OGR in Map 2008 just fine. I want to know how to use the
OGR FDO in MapGuide OS. Studio won't show the data type. Do you have to
set the resource manually using the web tier? If so what is an example
of the XML?
Thanks!
Chris
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070511/f38c8c60/attachment-0001.html
