[mapguide-users] OGR and MGOS
Chris Gountanis cgountanis at mpower-tech.com
Fri May 11 14:48:05 EDT 2007
OK I grabbed this version
http://download.osgeo.org/fdo/3.2.2-Beta1/OGRProvider-3.2.2_beta1.win32.zip
what is the proper procedure. I edited the provider.xml file. Same exact
thing I did for Map 2008 and it worked.
Also is there a Read/Write solution to OGR?
Chris
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Traian Stanev
Sent: Friday, May 11, 2007 1:41 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] OGR and MGOS
In Studio, create a New Data Connection. It will show a list of providers
including the OGR provider. When you press on that, it will bring up a
connection editor dialog that lets you set the OGR connection string. If the
provider does not show up in the list, then it is not installed correctly on
the server.
Traian
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris Gountanis
Sent: Friday, May 11, 2007 2:17 PM
To: 'MapGuide Users Mail List'
Subject: [mapguide-users] OGR and MGOS
I have used the OGR in Map 2008 just fine. I want to know how to use the OGR
FDO in MapGuide OS. Studio won't show the data type. Do you have to set the
resource manually using the web tier? If so what is an example of the XML?
Thanks!
Chris
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070511/9167a20a/attachment.html
