[mapguide-users] OGR and MGOS
Traian Stanev traian.stanev at autodesk.com
Fri May 11 14:58:34 EDT 2007
Edit providers.xml and then restart the server (I assume you put the DLL
in the /FDO/bin that belongs to the server). Then it should show up in
Studio. If it does not, check the dll dependencies using depends or
something...
As far as Write goes, it depends what you mean by write. Insert, Update,
Delete, Create Layer?
Traian
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris
Gountanis
Sent: Friday, May 11, 2007 2:48 PM
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] OGR and MGOS
OK I grabbed this version
http://download.osgeo.org/fdo/3.2.2-Beta1/OGRProvider-3.2.2_beta1.win32.
zip what is the proper procedure. I edited the provider.xml file. Same
exact thing I did for Map 2008 and it worked.
Also is there a Read/Write solution to OGR?
Chris
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Traian
Stanev
Sent: Friday, May 11, 2007 1:41 PM
To: MapGuide Users Mail List
In Studio, create a New Data Connection. It will show a list of
providers including the OGR provider. When you press on that, it will
bring up a connection editor dialog that lets you set the OGR connection
string. If the provider does not show up in the list, then it is not
installed correctly on the server.
Traian
Gountanis
Sent: Friday, May 11, 2007 2:17 PM
Subject: [mapguide-users] OGR and MGOS
I have used the OGR in Map 2008 just fine. I want to know how to use the
OGR FDO in MapGuide OS. Studio won't show the data type. Do you have to
set the resource manually using the web tier? If so what is an example
of the XML?
Thanks!
Chris
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070511/c97c7ffd/attachment.html
