[mapguide-users] Creating a new map from an existing layout
George McLean gmclean at gorge.net
Mon May 14 17:59:30 EDT 2007
This post is just correcting the subject line....
George McLean wrote:
> I have a map created in Autodesk's Mapguide Studio with feature data
> coming from a MySQL database. I would like to use this may layout with
> the associated feature styles and scale ranges with data from a
> different MySQL database containing data from another region but
> stored in a similar schema.
> I thought I could copy the layers, data connections etc from the
> original and just change the data connection to the MySQL database. I
> can create a connection to the new MySQL database but when I try and
> change the source for the layers, I get a message that states I am
> changing to an incompatible date resource and layer settings will
> reset to the defaults. This of course means I lose all the feature
> stylings.
> Is there a better way to reuse a given map layout and the associated
> layer stylings with new data?
> Is there another way to edit the data created by Mapguide Studio that
> might allow me to accomplish this?
> Is the data created by studio stored as XML or some other format?
> Any suggestions would be greatly appreciated!
> George McLean
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
