SPAM-LOW: Re: [mapguide-users] Creating
Andy Morsell amorsell at spatialgis.com
Mon May 14 17:25:26 EDT 2007
Actually via direct contact with some of the developers.  I'm not sure I
should give out their names and emails here, though.... Your best bet would
be to post these issues to the Autodesk MapGuide Enterprise discussion group
since it really is a Studio issue:
http://discussion.autodesk.com/forum.jspa?forumID=233
Andy
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of George McLean
Sent: Monday, May 14, 2007 3:13 PM
To: MapGuide Users Mail List
Subject: SPAM-LOW: Re: [mapguide-users] Creating
Thanks for the reply Andy. It looks like I could really do some damage with
MapAgent, should be fun :-)
If another voice lobbying Autodesk would help, I would be glad to put in my
vote for these changes. Are you submitting these requests through ADN?
Thanks
George
Andy Morsell wrote:
> I've been going back and forth with Autodesk on this issue as well.
> It happens if any attribute that is utilized anywhere within your
> current layer is not present in the new feature source.  This includes
> your filter where clause, the URL, tooltip, themes, labels, and so on.
> I believe that Autodesk is going to try to make Studio more forgiving
> in these cases so that "power" users can make these kinds of changes
> without the layer being completely reset.
> You could edit the resource XML directly using the MapAgent
> (http://localhost/mapguide/mapagent/index.html) or programmatically
> and bypass Studio.  This would involve saving the layer XML, modifying
> it, and then saving it back into the repository using the SetResource
> mapagent operation.
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
> From: mapguide-users-bounces at lists.osgeo.org
> McLean
> Sent: Monday, May 14, 2007 2:22 PM
> Subject: [mapguide-users] Creating
> I have a map created in Autodesk's Mapguide Studio with feature data
> coming from a MySQL database. I would like to use this may layout with
> the associated feature styles and scale ranges with data from a
> different MySQL database containing data from another region but stored in
a similar schema.
> I thought I could copy the layers, data connections etc from the
> original and just change the data connection to the MySQL database. I
> can create a connection to the new MySQL database but when I try and
> change the source for the layers, I get a message that states I am
> changing to an incompatible date resource and layer settings will
> reset to the defaults. This of course means I lose all the feature
stylings.
> Is there a better way to reuse a given map layout and the associated
> layer stylings with new data?
> Is there another way to edit the data created by Mapguide Studio that
> might allow me to accomplish this?
> Is the data created by studio stored as XML or some other format?
> Any suggestions would be greatly appreciated!
> George McLean
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
