[mapguide-users] Search for OGRProvider 3.1 or 3.0
Arnold Schwabe ars80 at telus.net
Thu May 17 22:43:20 EDT 2007
There is an issue when adding the OGR provider to Map 3D. In general, it
should work but you have to make sure your desktop shortcut starts in the
correct location. You will want to check the properties of the shortuct and
make sure it starts in:
C:\Program Files\Autodesk Map 3D 2007\
I think by default it starts in:
C:\Program Files\Autodesk Map 3D 2007\UserDataCache
By starting in the UserDataCache folder it likely won't work properly
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org]On Behalf Of xiexie
Sent: May 17, 2007 7:20 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Search for OGRProvider 3.1 or 3.0
I added the ORGProvider 3.2 to Map3d 2007 and modified the xml file.But when
I open the dialog to add an ogr data connection ,no box or button was on the
dialog,therefore I can't continue.
And there is a document tell me how to add ogrprovider to map3d, it use
ogrprovider 3.1 .But I can't find the file of OGRProvider 3.1 from
download.osgeo.org,can anybody give it to me ?
My mail is gisprogramer at 163.com,thank you!!
View this message in context:
http://www.nabble.com/Search-for-OGRProvider-3.1-or-3.0-tf3775387s16610.html
#a10675488
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
