[mapguide-users] Any example how connect to ArcSDE from codewithFDO
Brad Nesom kidsmake6 at msn.com
Wed May 23 12:09:27 EDT 2007
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=4144367
The sdk includes Autodesk FDO API Developer's Guide
http://images.autodesk.com/adsk/files/map3d_devguides.zip
http://www.autodesk.com/map3d-skillbuilders
these may help.
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Brad Nesom
Sent: Wednesday, May 23, 2007 11:01 AM
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] Any example how connect to ArcSDE from
codewithFDO
I don't have any code examples but one suggestion is to make sure you are
not using the db instance name but the arcsde instance name. such as 5151 or
esri_sde. I think there should also be some version parameters as default
store is one option and any other schema that contain sde data could also be
used and then the actual version name such as live or default or the version
name.( I am thinking of what parameters I see in the FDO connection for
arcsde in map)
Hope this helps
Brad
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of bigtower
Sent: Friday, May 18, 2007 2:17 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Any example how connect to ArcSDE from code
withFDO
Hi everyone,
Somebody has an example about how connect to ArcSDE (FDO) from code. I use
NET and I think that my problem is the string connection. I pass the
server, the instance, the user and the password.
Please if someones has an example code in .NET about an ArcSDE connection I
will be really grateful.
Thanks
View this message in context:
http://www.nabble.com/Any-example-how-connect-to-ArcSDE-from-code-with-FDO-t
f3776114s16610.html#a10677567
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
