[mapguide-users] MapGuide 1.2 Beta2, Login Error
Kenneth, GEOGRAF A/S ks at geograf.dk
Fri May 25 02:49:50 EDT 2007
The right version for MapGuide is 2.0.50727 aka 2.0.
And Andy is right, they co-exist, which can be rather confusing and has
some drawbacks.
I have never thought of the idea, that the default .Net version is the
one selected for the root folder of IIS, but it make  very good sense.
I have created a ticket for the problem, I don't know if it is actually
possible to change the default .Net version, as even the Visual Studio
2005 Installer for web applications has the same bug.
Mvh. Kenneth, GEOGRAF A/S
tlf.: +45 48 16 67 14
ks at geograf.dk
Andy Morsell wrote:
> Brad,
> If a server has ASP.NET 1.1.4322 installed and then you install .NET 2.0,
> the two co-exist rather than the new overwriting the old.  This is good
> since some applications written for 1.1 are not compatible with 2.0 so you
> can choose which version to use on an application by application basis.
> This same thing has happened to me several times on different servers and is
> the first thing I check on the mapguide virtual directory in IIS.  I believe
> it occurs if you have the root default web site properties set to use 1.1 so
> the MapGuide installer assumes that is the version to use when the mapguide
> virtual directory is created.
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> http://www.SpatialGIS.com
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Brad Nesom
> Sent: Thursday, May 24, 2007 1:59 PM
> To: 'MapGuide Users Mail List'
> Subject: RE: [mapguide-users] MapGuide 1.2 Beta2, Login Error
> How did you know what the right version was? What was it?
> I have 2.0.50727
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth,
> GEOGRAF A/S
> Sent: Thursday, May 24, 2007 4:42 AM
> To: MapGuide Users Mail List
> Subject: [mapguide-users] MapGuide 1.2 Beta2, Login Error
> After installing the MapGuide 1.2 Beta 2, I could not login to the MapGuide
> Site Admin. Tried restarting the server, but no change.
> Finally, I found out that the Installer had selected the wrong version of
> the .Net framework in IIS. Selecting the correct version on the top
> "mapguide" folder, fixed the login problem. Not sure why, since the site
> admin is running with php.
> Is it a know defect that the wrong version is selected?
> Regards, Kenneth, GEOGRAF A/S
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
