[mapguide-users] Building symbols
George McLean gmclean at gorge.net
Fri May 25 19:06:02 EDT 2007
Thanks for the suggestion James. I will give this a try. I am guessing
the ESRI symbols are proprietary and should not be used directly in MGOS
even though they work well. Does anyone know if the ESRI symbols need to
be licensed for use in MGOS?
Thanks
George McLean
James H. Murphy wrote:
> George,
> This is what I have been doing for the past few months between support calls and demos. In Map3D I create Mtext using charmap and getting the fonts from the ESRI symbol library. Then I use the express tool text explode to turn those mtext objects into lines/plines. Then I run some of the map cleanup tools on those to get rid of the duplicate lines and so-on. Clean up what is left over and create blocks by-layer. It takes a while but that seems to work with the ESRI fonts to create symbols you can use in the FDO side of MAP 3D. Once I get "all" of them convert cataloged somehow, haven't gotten to that point yet they will be available for anyone that wants then.
> Now whether they work in MGE or MGOS I don't know but for MAP3D they look good.
> James Murphy
> Applications Engineer
> ALACAD
>  (205)444-3100
> Visit us at www.alacad.com
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of George McLean
> Sent: Friday, May 25, 2007 3:46 PM
> To: MapGuide Users Mail List
> Subject: [mapguide-users] Building symbols
> Hello,
> I am looking for suggestions for creating nice looking symbols for MGOS
> using Atuodesk Mapguide Studio. I have tried loading DWG files with
> blocks that I would like to use with some success but I am having
> trouble repeating this with other blocks and I am not sure why at this
> point. Unfortunately when I did get some blocks to create symbols I
> like, I did not save the load procedure so I can not remember what
> parameters I set on the load procedure form! Are there any guidelines
> for what settings to use in the load procedure for creating symbols from
> autocad blocks?
> I would also be interested in any suggestions on other methods to create
> symbol libraries. I have tried to create fonts using FontCreater but
> have not been successful yet most likely due to not understanding what I
> am doing very well. I have tried to build a font library similar to the
> ESRI libraries but I must be missing some key steps. When I build a font
> and assign it to a position in the font table, I get the corresponding
> ascii character instead of my symbol.
> I have also tried importing bmp files into symbol libraries. but have
> not had much luck here either. I can see the BMP in the symbol library
> but when I style a point with it I can not see it in the map, layer
> preview or when trying to set the reference point. Are there any
> guidelines for this procedure like how big the file should be etc?
> Sorry for all the rambling but as you can see I am a bit lost on symbol
> creation.
> Thanks,
> George McLean
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
> No virus found in this incoming message.
> Checked by AVG Free Edition.
> Version: 7.5.467 / Virus Database: 269.8.0/817 - Release Date: 5/24/2007 4:01 PM
> No virus found in this outgoing message.
