[mapguide-users] Can't insert feature into certain SDFs
Takashige Nakagawa ta-nakagawa at apptec.co.jp
Sun May 27 20:29:16 EDT 2007
Hi, zak.
Thanks for the reply.
Yes, my code skips the autogenerated property.
And, even if I reduce properties except "Autogenerated_SDF_ID" and "SHPGEOM",
insertion doesn't work and returns no error.
Like I said, with some SDFs it works and with others not. I think properties
are not the cause.
Now I wonder if it has something with map's SRS...no, no, I don't know.
Regards.
Takashige Nakagawa
----- Original Message -----
> Hi,
> Does the feature you are trying to insert have any properties? Does
> your code handle skipping the autogenerated property?
> zak
