[mapguide-users] Connection problem with mysql
Dhirendra Kumar dhirendra.mgos at gmail.com
Wed May 30 06:16:56 EDT 2007
Hi veer,
I worked before this using shp file those are working verry fine but i am
also new in FDO and try to make layer using MySQL Datasource, If i solved
this, then definately i'll help you. By the be, first you import my given
file on mentioned Location and after that try to make connection using
Autodesk MapGuide studio with MySQL 5.0, In service text box write your
local machine IP Address or remote machine IP where MySQL is installed and
after that select <b<Use the following credentials and enter your MySQL user
name and Password. Click on Data source, then you will get all database of
your MySQL and after that Click on Test Connection for checking your
connection it will display Connection Successfully.
By the be i am INDIAN but this is not big issue, we all are come on NABBLE
for help and if you have some idea about my problem then you help me and if
i have solve of your problem then i will help you.
Regards,
Dhirendra Kumar
Kolkata
veer pal singh wrote:
> Hi Dhirendra,
>                  Thanks lot for reply to me, Dhirendra what u have write
> me i did that but u know i'm very new to mapguide so plz write me steps
> how can i connect my application to it. send me any example.
> how can i create a layer at run time. plz i'm also indian & i'm 100% sure
> u r too indian. plz help me.
> i'm waiting for ur reply.............
> thanks & regards
> veer pal singh
> noida
> Dhirendra Kumar wrote:
>> Hi veer,
>> If you want to connect MGOS with MySQL then you will have to install
>> MySQL 5.0 and if you use MGOS 1.1.0 then no need to configure FDO 3.2, I
>> am sending one libmysql.dll file you just copy on two location first
>> C:\Program Files\MapGuideOpenSource\Server\Bin\FDO and C:\Program
>> Files\Autodesk\MapGuideStudio2007\FDO.I also establish MySQL connection
>> using this way.
>> Regards,
>> Dhirendra Kumar http://www.nabble.com/file/p10867359/libmysql.dll
>> libmysql.dll
>>> Hi All,
>>> I read your(many of u) message that you succesfully connect MGOS with
>>> MySQL
>>> 5.0. I also
>>> want to connect with MySQL but i have not idea where i get FDO 3.2 and
>>> how
>>> to install it. In my next project i have to use MySQL as a Database for
>>> runtime layer creation but till now i have not idea. You succesfully
>>> connect
>>> with MySQL so, please help me. If you can send any Example or Query
>>> feature
>>> then i'll get more help. I am waiting for your replay. Please Help me.
>>> Thankyou in Advance.
>>> Regards,
>>> veer pal singh
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/Connection-problem-with-mysql-tf3832500s16610.html#a10870923
