[mapguide-users] RE: MySQL Database Feature Source Cordiante System
Kenneth, GEOGRAF A/S ks at geograf.dk
Wed May 30 10:11:19 EDT 2007
I think you have a problem with the database schema then.
I don't think there is any live support, as this is an open source project.
If you want real support, consider purchasing MapGuide Enterprise from
Autodesk.
Its basically the same product, but you get access to Autodesk support.
Regards, Kenneth, GEOGRAF A/S
Dhirendra Kumar wrote:
> Hi Kenneth,
> I am waiting for your replay. Please read my previous message for detail.
> Regards,
> Dhirendra Kumar
>> Hi Kenneth,
>> As per your suggestion i can view all tables during layer creation but
>> after selection of table lower Geometry combo box is empty not any data in
>> this combo box. Then how will i select "Geometry".In my process any thing
>> wrong ?. Kenneth i want to live chat with any MGOS Expert, Is it possible
>> Regards,
>> Dhirendra Kumar
>> Kenneth, GEOGRAF A/S wrote:
>>> Oh, my fault. It takes the two coorner coordinates, not a center
>>> coordinate.
>>> You must enter correct coordinates in the "lower left" and "upper right"
>>> boxes.
>>> You must also select the correct coordinate system.
>>> When you create a new layer, you must select a datasource.
>>> After selecting the data source, the names of the tables in the
>>> datasource should display in the combo box "Feature class".
>>> You can select the desired table here.
>>> You can select the column containing the geometry in the combobox
>>> "Geometry".
>>>> Hi Kenneth,
>>>> First i want to give you thankyou for your quick replay. Acording to you
>>>> when i go to create Layer then i can view only  Data resource used in
>>>> this
>>>> layer  field and select saved Datasource name and i save this layer as a
>>>> same name of Datasource But i am not getting tables name individually
>>>> and
>>>> after that i make map using this layer then i can view only Coordinate
>>>> system option and initial view option for initial Zoom setting option
>>>> But i
>>>> am not getting any option for center coordinate. For Information i am
>>>> using
>>>> MGOS 1.1.0, MySQL 5.0 and Autodesk mapguide studio 2007.So please help
>>>> me.
>>>> Regards,
>>>> Dhirendra Kumar
>>>>> You cannot see the tables on the datasource. That is by design. The
>>>>> tables are considered schema's within the datasource.
>>>>> You should be able to see all the tables, when you are creating the
>>>>> layer.
>>>>> When working with databases, I would recommend not using any
>>>>> non-english
>>>>> charaters, even though the database supports it. Many third-party
>>>>> applications break when they encounter such characters.
>>>>> Did you enter the center coordinate on the map?
>>>>> Try looking at the MapGuide log files. They should be in
>>>>> C:\Program Files\MapGuideOpenSource\Server\Logs
>>>>> There might be a message if something went wrong.
>>>>>> Hi Kenneth,
>>>>>> As per your suggestion first i create one datasource (Connection was
>>>>>> succesfull) and after that create layer with existing datasource, and
>>>>>> also
>>>>>> create map and mention cordinate system. But my problem is still same.
>>>>>> In
>>>>>> MySQL Database one table with 15 fields and i want to create Points on
>>>>>> field
>>>>>> Longitude and Latitude. Any problem in this field name ? During
>>>>>> creation
>>>>>> of
>>>>>> datasource, not getting any option to select any specific table but
>>>>>> when
>>>>>> i
>>>>>> use join feature then i can view all tables name for join purpose.
>>>>>> Help
>>>>>> me......
>>>>>> Regards,
>>>>>> Dhirendra Kumar
>>>>>>> As Dave wrote, you must zoom in to the data.
>>>>>>> Since you cannot enter coordinates on the layer preview, it will not
>>>>>>> show.
>>>>>>> To view data you must:
>>>>>>> Create a datasource.
>>>>>>> Create a layer with the datasource.
>>>>>>> Create a map.
>>>>>>> Select the coordinate system.
>>>>>>> Specify the center coordinate manually.
>>>>>>> Add the layer.
>>>>>>> Press refresh.
>>>>>>> If it still won't show, doublecheck the connection on the datasource,
>>>>>>> and press the "Test connection" button.
>>>>>>>> Hi Dave,
>>>>>>>> You are right, not any fied in autodesk studio 2007 for mention
>>>>>>>> cordinate
>>>>>>>> system but when i am creating layer using data source, then why
>>>>>>>> Layer
>>>>>>>> is
>>>>>>>> not
>>>>>>>> showing in map preview window of Autodesk studio 2007. Please help
>>>>>>>> me
>>>>>>>> ....... Thankyou in Advance.
>>>>>>>> Regards,
>>>>>>>> Dhirendra Kumar
>>>>>>>> Dave Wilson-3 wrote:
>>>>>>>>> As per my previous email unless you have the new MGOS beta there is
>>>>>>>>> no
>>>>>>>>> field to specify a coordinate system override since currently MySQL
>>>>>>>>> doesn't support coordinate systems in the native schema. You can
>>>>>>>>> specify
>>>>>>>>> the correct coordinate system in your map but you will have to zoom
>>>>>>>>> and
>>>>>>>>> find the data to set the extent yourself.
>>>>>>>>> Regards,
>>>>>>>>> Dave
>>>>>>>>> -----Original Message-----
>>>>>>>>> From: mapguide-users-bounces at lists.osgeo.org
>>>>>>>>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of
>>>>>>>>> Dhirendra
>>>>>>>>> Kumar
>>>>>>>>> Sent: Monday, May 28, 2007 5:07 AM
>>>>>>>>> To: mapguide-users at lists.osgeo.org
>>>>>>>>> Subject: [mapguide-users] MySQL Database Feature Source Cordiante
>>>>>>>>> System
>>>>>>>>> Hi All,
>>>>>>>>> I have successfully established connection of MySQL 5.0 Database
>>>>>>>>> and
>>>>>>>>> mapguide 1.1.0 with the help of Autodesk MapGuide Studio 2007 but
>>>>>>>>> when
>>>>>>>>> creating Layer using this data source then layer is not showing in
>>>>>>>>> autodesk
>>>>>>>>> Layer Preview window, I think this is happning due to cordinate
>>>>>>>>> system,
>>>>>>>>> If i
>>>>>>>>> am right then where is option of providing cordinate system of
>>>>>>>>> MySQL
>>>>>>>>> data
>>>>>>>>> source ? If i am wrong then please give me idea, How to solve this
>>>>>>>>> problem ?
>>>>>>>>> Regards,
>>>>>>>>> Dhirendra Kumar
>>>>>>>>> View this message in context:
>>>>>>>>> http://www.nabble.com/MySQL-Database-Feature-Source-Cordiante-System-tf3
>>>>>>>>> 827380s16610.html#a10834515
>>>>>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>>>>>>> _______________________________________________
>>>>>>>>> mapguide-users mailing list
>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070530/41ac502d/attachment.html
