[mapguide-users] RE: MySQL Database Feature Source CordianteSystem
Dave Wilson dave.wilson at autodesk.com
Wed May 30 10:36:22 EDT 2007
I reread the email chain and noticed you talked about Points and
Longitude and Latitude columns. If that is the case you shouldn't use
the MySQL provider, but instead use an ODBC connection. You will need to
install the MySQL ODBC Connector on your server system (it's the ODBC
driver for MySQL).
You likely don't have any geometry because there are no geometry type
columns in your data.
Regards,
Dave
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth,
GEOGRAF A/S
Sent: Wednesday, May 30, 2007 8:11 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] RE: MySQL Database Feature Source
CordianteSystem
I think you have a problem with the database schema then.
I don't think there is any live support, as this is an open source
project.
If you want real support, consider purchasing MapGuide Enterprise from
Autodesk.
Its basically the same product, but you get access to Autodesk support.
Regards, Kenneth, GEOGRAF A/S
Dhirendra Kumar wrote:
Hi Kenneth,
I am waiting for your replay. Please read my previous message for
detail.
Regards,
Dhirendra Kumar
	Hi Kenneth,
	As per your suggestion i can view all tables during layer
creation but
	after selection of table lower Geometry combo box is empty not
any data in
	this combo box. Then how will i select "Geometry".In my process
any thing
	wrong ?. Kenneth i want to live chat with any MGOS Expert, Is it
possible
	Regards,
	Dhirendra Kumar
	Kenneth, GEOGRAF A/S wrote:
		Oh, my fault. It takes the two coorner coordinates, not
a center
		coordinate.
		You must enter correct coordinates in the "lower left"
and "upper right"
		boxes.
		You must also select the correct coordinate system.
		When you create a new layer, you must select a
datasource.
		After selecting the data source, the names of the tables
in the
		datasource should display in the combo box "Feature
class".
		You can select the desired table here.
		You can select the column containing the geometry in the
combobox
		"Geometry".
			Hi Kenneth,
			First i want to give you thankyou for your quick
replay. Acording to you
			when i go to create Layer then i can view only
Data resource used in
			this
			layer  field and select saved Datasource name
and i save this layer as a
			same name of Datasource But i am not getting
tables name individually
			and
			after that i make map using this layer then i
can view only Coordinate
			system option and initial view option for
initial Zoom setting option
			But i
			am not getting any option for center coordinate.
For Information i am
			using
			MGOS 1.1.0, MySQL 5.0 and Autodesk mapguide
studio 2007.So please help
			me.
			Regards,
			Dhirendra Kumar
				You cannot see the tables on the
datasource. That is by design. The
				tables are considered schema's within
the datasource.
				You should be able to see all the
tables, when you are creating the
				layer.
				When working with databases, I would
recommend not using any
				non-english
				charaters, even though the database
supports it. Many third-party
				applications break when they encounter
such characters.
				Did you enter the center coordinate on
the map?
				Try looking at the MapGuide log files.
They should be in
				C:\Program
Files\MapGuideOpenSource\Server\Logs
				There might be a message if something
went wrong.
				Hi Kenneth,
				As per your suggestion first i create
one datasource (Connection was
				succesfull) and after that create layer
with existing datasource, and
				also
				create map and mention cordinate system.
But my problem is still same.
				In
				MySQL Database one table with 15 fields
and i want to create Points on
				field
				Longitude and Latitude. Any problem in
this field name ? During
				creation
				of
				datasource, not getting any option to
select any specific table but
				when
				i
				use join feature then i can view all
tables name for join purpose.
				Help
				me......
				Regards,
				Dhirendra Kumar
				As Dave wrote, you must zoom in to the
data.
				Since you cannot enter coordinates on
the layer preview, it will not
				show.
				To view data you must:
				Create a datasource.
				Create a layer with the datasource.
				Create a map.
				Select the coordinate system.
				Specify the center coordinate manually.
				Add the layer.
				Press refresh.
				If it still won't show, doublecheck the
connection on the datasource,
				and press the "Test connection" button.
				Hi Dave,
				You are right, not any fied in autodesk
studio 2007 for mention
				cordinate
				system but when i am creating layer
using data source, then why
				Layer
				is
				not
				showing in map preview window of
Autodesk studio 2007. Please help
				me
				....... Thankyou in Advance.
				Regards,
				Dhirendra Kumar
				Dave Wilson-3 wrote:
				As per my previous email unless you have
the new MGOS beta there is
				no
				field to specify a coordinate system
override since currently MySQL
				doesn't support coordinate systems in
the native schema. You can
				specify
				the correct coordinate system in your
map but you will have to zoom
				and
				find the data to set the extent
yourself.
				Regards,
				Dave
				-----Original Message-----
				Dhirendra
				Kumar
				Sent: Monday, May 28, 2007 5:07 AM
				To: mapguide-users at lists.osgeo.org
				Subject: [mapguide-users] MySQL Database
				System
				Hi All,
				I have successfully established
connection of MySQL 5.0 Database
				and
				mapguide 1.1.0 with the help of Autodesk
MapGuide Studio 2007 but
				when
				creating Layer using this data source
then layer is not showing in
				autodesk
				Layer Preview window, I think this is
happning due to cordinate
				system,
				If i
				am right then where is option of
providing cordinate system of
				MySQL
				data
				source ? If i am wrong then please give
me idea, How to solve this
				problem ?
				Regards,
				Dhirendra Kumar
				View this message in context:
http://www.nabble.com/MySQL-Database-Feature-Source-Cordiante-System-tf3
				827380s16610.html#a10834515
				Sent from the MapGuide Users mailing
list archive at Nabble.com.
				mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070530/94748eae/attachment.html
