[mapguide-users] Error.log of MapGuide Enterprise
Jack Lee jack.lee at autodesk.com
Sat Nov 3 14:21:39 EDT 2007
I am not sure which FDO version you are using but providers.xml would be under a directory like:
/usr/local/fdo-3.2.2/lib.
________________________________________
From: mapguide-users-bounces at lists.osgeo.org [mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth, GEOGRAF A/S [ks at geograf.dk]
Sent: Saturday, November 03, 2007 1:15 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Error.log of MapGuide Enterprise
It should be located in server/bin/fdo, along with at least SDFProvider.o and SHPProvider.o.
I'm unfamilliar with the Linux install package, but you need the FDO Providers, if they are not included in the package.
Regards, Kenneth, GEOGRAF A/S
Eric123 skrev:
Thanks Jack.
I try to locate "providers.xml". Nothing can find. What is the exact
directory for the file?
Eric
Jack Lee-3 wrote:
Does the file providers.xml exist?
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org<mailto:mapguide-users-bounces at lists.osgeo.org>
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Eric123
Sent: Saturday, November 03, 2007 7:45 AM
To: mapguide-users at lists.osgeo.org<mailto:mapguide-users at lists.osgeo.org>
Subject: [mapguide-users] Error.log of MapGuide Enterprise
Hi All.
I just installed the MGE2008 to Fedora Core 4. Actually I try to use
MapGuide Studio 2008, Fusion viewer, DWF viewer, the map cannot be
generated. OK I check with the error.log. I got the following warning.
Anyone know how to fix? Do I need to re-install/compile FDO?
Thanks in advance.
Eric>-(
<2007-11-01T16:49:15>                   Administrator
 Error: An exception occurred in FDO component.
        CLNT_12_FILE_NOT_EXISTS
 StackTrace:
  - MgFeatureServiceHandler.ProcessOperation line 83 file
FeatureServiceHandler.cpp
  - MgOpGetIdentityProperties.Execute line 116 file
OpGetIdentityProperties.cpp
  - MgServerDescribeSchema.GetIdentityProperties line 1581 file
ServerDescribeSchema.cpp
  - MgServerDescribeSchema.ExecuteDescribeSchema line 173 file
  - MgFdoConnectionManager.Open line 259 file FdoConnectionManager.cpp  An
<2007-11-01T16:49:16>                   Administrator
 Error: Failed to stylize layer: CityLimits
 StackTrace:
  - MgStylizationUtil.StylizeLayers line 923 file StylizationUtil.cpp
View this message in context:
http://www.nabble.com/Error.log-of-MapGuide-Enterprise-tf4742649s16610.html#a13562055
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
