[mapguide-users] Error.log of MapGuide Enterprise
Eric123 erictsn at cadbeyond.com
Sat Nov 3 21:39:47 EDT 2007
Hi Jack,
Thanks.
But under the fdo-3.2.2 directory, I cannot find the providers.xml file!
[root at localhost lib]# ls
com                           libSchemaMgr_OV.la
FdoATILConfiguration.xml      libSchemaMgr_OVOR.so
libArcSDEProvider-3.2.2.so    libSchemaMgr_OV.so
libArcSDEProvider91-3.2.2.so  libSDFProvider-3.2.2.so
libArcSDEProvider91.la        libSDFProvider.la
libArcSDEProvider91.so        libSDFProvider.so
libArcSDEProvider92-3.2.2.so  libSHPOverrides-3.2.2.so
libArcSDEProvider92.la        libSHPOverrides.la
libArcSDEProvider92.so        libSHPOverrides.so
libArcSDEProvider.la          libSHPProvider-3.2.2.so
libArcSDEProvider.so          libSHPProvider.la
libFDO-3.2.2.so               libSHPProvider.so
libFdoATILSession.so          libUserMgr-3.2.2.so
libFDO.la                     libUserMgr.la
libFdoMySQL-3.2.2.so          libUserMgr.so
libFdoMySQL.la                libWFSProvider-3.2.2.so
libFdoMySQL.so                libWFSProvider.la
libFdoODBC-3.2.2.so           libWFSProvider.so
libFdoODBC.la                 libWMSOverrides-3.2.2.so
libFdoODBC.so                 libWMSOverrides.la
libFdoOws-3.2.2.so            libWMSOverrides.so
libFdoOws.la                  libWMSProvider-3.2.2.so
libFdoOws.so                  libWMSProvider.la
libFdoRdbms.so                libWMSProvider.so
libFDO.so                     libxalan-c.so
libgdal.so                    libxalanMsg.so
libgdal.so.1                  libxalanMsg.so.17
libgdal.so.1.9.0              libxalanMsg.so.17.0
libRFPOverrides.so            libxerces-c.so
libRFPProvider.so             libxerces-c.so.25
libSchemaMgr_OV-3.2.2.so      libxerces-c.so.25.0
Eric
Jack Lee-3 wrote:
> Hi,
> I am not sure which FDO version you are using but providers.xml would be
> under a directory like:
> /usr/local/fdo-3.2.2/lib.
> ________________________________________
> From: mapguide-users-bounces at lists.osgeo.org
> [mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth, GEOGRAF A/S
> [ks at geograf.dk]
> Sent: Saturday, November 03, 2007 1:15 PM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] Error.log of MapGuide Enterprise
> It should be located in server/bin/fdo, along with at least SDFProvider.o
> and SHPProvider.o.
> I'm unfamilliar with the Linux install package, but you need the FDO
> Providers, if they are not included in the package.
> Regards, Kenneth, GEOGRAF A/S
> Eric123 skrev:
> Thanks Jack.
> I try to locate "providers.xml". Nothing can find. What is the exact
> directory for the file?
> Eric
> Jack Lee-3 wrote:
> Hi,
> Does the file providers.xml exist?
> -----Original Message-----
> From:
> mapguide-users-bounces at lists.osgeo.org<mailto:mapguide-users-bounces at lists.osgeo.org>
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Eric123
> Sent: Saturday, November 03, 2007 7:45 AM
> To: mapguide-users at lists.osgeo.org<mailto:mapguide-users at lists.osgeo.org>
> Subject: [mapguide-users] Error.log of MapGuide Enterprise
> Hi All.
> I just installed the MGE2008 to Fedora Core 4. Actually I try to use
> MapGuide Studio 2008, Fusion viewer, DWF viewer, the map cannot be
> generated. OK I check with the error.log. I got the following warning.
> Anyone know how to fix? Do I need to re-install/compile FDO?
> Thanks in advance.
> Eric>-(
> <2007-11-01T16:49:15>                   Administrator
>  Error: An exception occurred in FDO component.
>         CLNT_12_FILE_NOT_EXISTS
>  StackTrace:
>   - MgFeatureServiceHandler.ProcessOperation line 83 file
> FeatureServiceHandler.cpp
>   - MgOpGetIdentityProperties.Execute line 116 file
> OpGetIdentityProperties.cpp
>   - MgServerDescribeSchema.GetIdentityProperties line 1581 file
> ServerDescribeSchema.cpp
>   - MgServerDescribeSchema.ExecuteDescribeSchema line 173 file
>   - MgFdoConnectionManager.Open line 259 file FdoConnectionManager.cpp  An
> <2007-11-01T16:49:16>                   Administrator
>  Error: Failed to stylize layer: CityLimits
>  StackTrace:
>   - MgStylizationUtil.StylizeLayers line 923 file StylizationUtil.cpp
> http://www.nabble.com/Error.log-of-MapGuide-Enterprise-tf4742649s16610.html#a13562055
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://www.nabble.com/Error.log-of-MapGuide-Enterprise-tf4742649s16610.html#a13569196
