[mapguide-users] ODBC and regional settings
Jason Birch Jason.Birch at nanaimo.ca
Tue Apr 1 16:30:40 EDT 2008
Could you please test this against MapGuide 2.0, and if it is still a
problem enter a ticket in the Trac database?
http://trac.osgeo.org/mapguide/wiki/SubmitTicket
If you can make sample data available, and fully describe your operating
environment, it will be more likely to be addressed by the developers.
My suspicion is that this may be an FDO issue more than a MapGuide
issue.  Perhaps it would be better in the FDO trac?
http://trac.osgeo.org/fdo/wiki/SubmitTicket
Jason
-----Original Message-----
Subject: [mapguide-users] ODBC and regional settings
After I did a conversion from the datatype of the geometry columns
(decimal
to long integer) the problem was solved. So it seems that MGOS can not
handle with decimal numbers when the regional settings are US different
Can this be tracked as a bug ?
