[mapguide-users] can't update and delete from feature source but insert works
J Manafi jonathan.manafi at cctechnol.com
Fri Apr 4 11:06:19 EDT 2008
I have not received any error messages. All of our php script files execute
fine and return all the expected values through FireBug as if they are
executing correctly. I am also not seeing your issue of not being able to
insert anymore, because I have now tried that, where I have an
UpdateFeatures followed by an InsertFeatures, and all of the features are
getting inserted every time but not updated.  I have taken the advice of the
other threads and tried closing any and all featureReaders I could find, but
that has had no effect.
Just for reference, I am using MG 1.2 with bundled php environment.
Does anyone have any more suggestions?
Thanks in advance for any help you give.
Ismael Cams wrote:
> Hello,
> I started a thread on the forum yesterday similar to what you are
> describing. Did you get any error messages (I get an
> MgResourceBusyException) ? After I try to delete or update a feature I
> also not succeed anymore to insert features. Only after a restart of
> mgserver I can insert features again.
> My code was working fine with MGOS 1.2.
> J Manafi wrote:
>> I am having a very similar problem. We are digitizing layers and storing
>> temporary feature sources in the session repository, and I, too, cannot
>> delete or update our temp. layers, but I can insert new features. I
>> checked the readonly flag, but it was already set to FALSE, and my
>> attempts at updating features are very similar programatically to the
>> posts I have already come across.  We are able to do a mass deletion,
>> however, and delete all temporary layers from the map, but I have been
>> unsuccessful in trying to delete a singular feature from specific layers.
>> Has anyone been able to make any progress on this topic?
>> mitcha wrote:
>>> hello everybody,
>>> i need help!!!  i try tu update and delete a feature source (sdf file),
>>> but it doesn't work! instead inserting new data into feature source work
>>> very well! i searched for solutions in this forum and i found some
>>> similar problems.
>>> So I first tried to set the readonly flag of the schema to false with
>>> the mapagent. now the xml presentation looks like this:
>>> OSGeo.SDF
>>> File
>>> %MG_DATA_FILE_PATH%userPoints2.sdf
>>> ReadOnly
>>> FALSE
>>> But it doesn't work!!!
>>> furthermore i tried to set the identity property to readonly="false"
>>> with the help of Fdo2Fdo. But it doesn't work, too. i always get an
>>> error message. Could this be my fault? can i change this value of the
>>> identity property?
View this message in context: http://www.nabble.com/can%27t-update-and-delete-from-feature-source-but-insert-works-tp12233926s16610p16491865.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080404/db19c1b8/attachment.html
