[mapguide-users] can't update and delete from feature source but insert works
J Manafi jonathan.manafi at cctechnol.com
Fri Apr 4 12:19:10 EDT 2008
Does anyone know...with an MgDeleteFeatures(or perhaps MgUpdateFeatures)
command, does the filter string have to be of a certain type? For instance,
we have features stored with a unique KEY value. It used to be of type
'Int32', and it seemed that DeleteFeatures was working back then. But then I
changed the KEY value to type 'String' to make it more dynamic, and that
seems to be when this breakdown started happening.
Our filter string looks like this: $filter = "KEY = $ID";
Should the fact that $ID is a string matter at all?
J Manafi wrote:
> I have not received any error messages. All of our php script files
> execute fine and return all the expected values through FireBug as if they
> are executing correctly. I am also not seeing your issue of not being able
> to insert anymore, because I have now tried that, where I have an
> UpdateFeatures followed by an InsertFeatures, and all of the features are
> getting inserted every time but not updated.  I have taken the advice of
> the other threads and tried closing any and all featureReaders I could
> find, but that has had no effect.
Just for reference, I am using MG 1.2 with bundled php environment.
Does anyone have any more suggestions?
Thanks in advance for any help you give.
> Ismael Cams wrote:
>> Hello,
>> I started a thread on the forum yesterday similar to what you are
>> describing. Did you get any error messages (I get an
>> MgResourceBusyException) ? After I try to delete or update a feature I
>> also not succeed anymore to insert features. Only after a restart of
>> mgserver I can insert features again.
>> My code was working fine with MGOS 1.2.
>> J Manafi wrote:
>>> I am having a very similar problem. We are digitizing layers and storing
>>> temporary feature sources in the session repository, and I, too, cannot
>>> delete or update our temp. layers, but I can insert new features. I
>>> checked the readonly flag, but it was already set to FALSE, and my
>>> attempts at updating features are very similar programatically to the
>>> posts I have already come across.  We are able to do a mass deletion,
>>> however, and delete all temporary layers from the map, but I have been
>>> unsuccessful in trying to delete a singular feature from specific
>>> layers.  Has anyone been able to make any progress on this topic?
>>> mitcha wrote:
>>>> hello everybody,
>>>> i need help!!!  i try tu update and delete a feature source (sdf file),
>>>> but it doesn't work! instead inserting new data into feature source
>>>> work very well! i searched for solutions in this forum and i found some
>>>> similar problems.
>>>> So I first tried to set the readonly flag of the schema to false with
>>>> the mapagent. now the xml presentation looks like this:
>>>> OSGeo.SDF
>>>> File
>>>> %MG_DATA_FILE_PATH%userPoints2.sdf
>>>> ReadOnly
>>>> FALSE
>>>> But it doesn't work!!!
>>>> furthermore i tried to set the identity property to readonly="false"
>>>> with the help of Fdo2Fdo. But it doesn't work, too. i always get an
>>>> error message. Could this be my fault? can i change this value of the
>>>> identity property?
View this message in context: http://www.nabble.com/can%27t-update-and-delete-from-feature-source-but-insert-works-tp12233926s16610p16492944.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080404/701a467f/attachment.html
