[mapguide-users] FDO - CLNT_8 error
Marc Pfister mpfister at enplan.com
Mon Apr 21 19:14:22 EDT 2008
I am logged in as root, so that's not the problem.
I'm also not using Oracle.
Is there a way to figure out which provider is causing the problems?
Marc
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
Sent: Monday, April 21, 2008 3:48 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] FDO - CLNT_8 error
I've usually seen this error when the library files for a database
provider (Oracle in particular) can't be found either in the FDO
directory or via the LD_LIBRARY_PATH. Alternately are you logged in as
another user that might not have access to some client library files?
With Oracle on Linux it's important to have an ORACLE_HOME and a
TNS_ADMIN set and the LD_LIBRARY_PATH set to include the path to the
Oracle client libraries.
Dave
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Marc
Pfister
Sent: Monday, April 21, 2008 4:09 PM
Subject: [mapguide-users] FDO - CLNT_8 error
Some new strangeness -
I have MGOS 1.2 installed on FC6 and previously it was working just
fine.
Now for some reason I'm getting:
1863|2630790032) An exception occurred in FDO component.
CLNT_8_UNABLE_TO_LOAD_LIBRARY
Exception occurred in method MgFdoConnectionManager.Open at line 259 in
file FdoConnectionManager.cpp
This seems to mean FDO can't access one of the providers.
If I snoop around the FDO libs with ldd, it says the libFDO-3.2.2 it
can't find the xalan and xerces libraries. Which is strange, because
they are in that same folder. If I export the FDO lib folder to
LD_LIBRARY_PATH then ldd is able to find the libraries to link to, but I
still get the error.
I have tried both a clean and a subsequent install of both the FDO and
ThirdParty scripts with no change in the error message.
Any ideas? Do  I need to reinstall the Mapguide side too?
n
Marc Pfister
Geospatial Data Manager
ENPLAN
530/221-0440 x108
530/221-6963 Fax
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080421/432d05da/attachment.html
