[mapguide-users] FDO - CLNT_8 error
Jack Lee jack.lee at autodesk.com
Mon Apr 21 19:43:54 EDT 2008
Try setting:
export NLSPATH=$NLSPATH:/usr/local/fdo-3.2.2/nls/%N
and restart the MapGuide server.
You might get more information about the error.
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Marc Pfister
Sent: Monday, April 21, 2008 7:14 PM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] FDO - CLNT_8 error
I am logged in as root, so that's not the problem.
I'm also not using Oracle.
Is there a way to figure out which provider is causing the problems?
Marc
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
Sent: Monday, April 21, 2008 3:48 PM
I've usually seen this error when the library files for a database provider (Oracle in particular) can't be found either in the FDO directory or via the LD_LIBRARY_PATH. Alternately are you logged in as another user that might not have access to some client library files?
With Oracle on Linux it's important to have an ORACLE_HOME and a TNS_ADMIN set and the LD_LIBRARY_PATH set to include the path to the Oracle client libraries.
Dave
Sent: Monday, April 21, 2008 4:09 PM
Subject: [mapguide-users] FDO - CLNT_8 error
Some new strangeness -
I have MGOS 1.2 installed on FC6 and previously it was working just fine.
Now for some reason I'm getting:
1863|2630790032) An exception occurred in FDO component.
CLNT_8_UNABLE_TO_LOAD_LIBRARY
Exception occurred in method MgFdoConnectionManager.Open at line 259 in file FdoConnectionManager.cpp
This seems to mean FDO can't access one of the providers.
If I snoop around the FDO libs with ldd, it says the libFDO-3.2.2 it can't find the xalan and xerces libraries. Which is strange, because they are in that same folder. If I export the FDO lib folder to LD_LIBRARY_PATH then ldd is able to find the libraries to link to, but I still get the error.
I have tried both a clean and a subsequent install of both the FDO and ThirdParty scripts with no change in the error message.
Any ideas? Do  I need to reinstall the Mapguide side too?
n
Marc Pfister
Geospatial Data Manager
ENPLAN
mpfister at enplan.com
530/221-0440 x108
530/221-6963 Fax
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080421/6f6466d0/attachment.html
