[mapguide-users] MGOS 2.0.0 problem loading imagery
David Nuell nuell at nicholsenvironmental.com
Fri Apr 25 12:28:11 EDT 2008
Bingo.  Thank you that worked.
I had to upload the data to a shared folder on the server.  Here are the
steps I did to make it work:
- connect to site
- right click and select New Data connection
- select OSGeo FDO Provider for Raster
- input my value in the connection properties
(D:\MapGuideStudioData\image.tif).  This is the location on the SERVER not
local
- save as 'raster connection'
- create layer and connect to data resource 'raster connection'
- save layer
- create map with extents that cover image extents (+/- 100m on lower left
and upper right)
- save map and preview
Thanks Dave Wilson!
Dave Wilson-3 wrote:
> The image data needs to reside on the server which it's not clear if that
> is the case from your details. You can either setup folders for your data
> and configure an Alias in Site Administrator or supply a UNC path to the
> server folder and that will likely work. If the data is to be accessed off
> the server then your mgserver process needs to run under a network ID that
> has a share rights to wherever the data is.
> Regards,
> Dave
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of David Nuell
> Sent: Thursday, April 24, 2008 12:02 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] MGOS 2.0.0 problem loading imagery
> Hi All -
> I am having an issue loading .tif imagery into Mapguide Studio (2008).  I
> am
> running MGOS v 2.0.0 on a win 2003 server.
> I have gone through various posts here on the forum and tried the
> suggestions with no success.  Here is what I am doing:
> - connect to site
> (C:\MapGuideStudioData\image.tif)
> - save layer
> and upper right)
> when I preview the map, nothing comes up.  The tif image isn't very big
> (10Mb).  I am not getting any other errors, etc.
> Can anyone please make a suggestion as to what to do?  Many thanks in
> advance!
> cheers.
> http://www.nabble.com/MGOS-2.0.0-problem-loading-imagery-tp16851301p16851301.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://www.nabble.com/MGOS-2.0.0-problem-loading-imagery-tp16851301p16897597.html
