[mapguide-users] MGOS 2.0.0 problem loading imagery
Dave Wilson dave.wilson at autodesk.com
Thu Apr 24 14:09:42 EDT 2008
The image data needs to reside on the server which it's not clear if that is the case from your details. You can either setup folders for your data and configure an Alias in Site Administrator or supply a UNC path to the server folder and that will likely work. If the data is to be accessed off the server then your mgserver process needs to run under a network ID that has a share rights to wherever the data is.
Regards,
Dave
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of David Nuell
Sent: Thursday, April 24, 2008 12:02 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] MGOS 2.0.0 problem loading imagery
Hi All -
I am having an issue loading .tif imagery into Mapguide Studio (2008).  I am
running MGOS v 2.0.0 on a win 2003 server.
I have gone through various posts here on the forum and tried the
suggestions with no success.  Here is what I am doing:
- connect to site
- right click and select New Data connection
- select OSGeo FDO Provider for Raster
- input my value in the connection properties
(C:\MapGuideStudioData\image.tif)
- save as 'raster connection'
- create layer and connect to data resource 'raster connection'
- save layer
- create map with extents that cover image extents (+/- 100m on lower left
and upper right)
- save map and preview
when I preview the map, nothing comes up.  The tif image isn't very big
(10Mb).  I am not getting any other errors, etc.
Can anyone please make a suggestion as to what to do?  Many thanks in
advance!
cheers.
View this message in context: http://www.nabble.com/MGOS-2.0.0-problem-loading-imagery-tp16851301p16851301.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
