[mapguide-users] Map doesn't zoom and center after search&select
Haris Kurtagic haris at sl-king.com
Fri Aug 1 04:08:15 EDT 2008
Hi Dragan,
Perhaps Spatia index ?
Perhaps not easy to setup test but you could try with Fdo2Fdo to run
query with spatial intersect envelope against that Oracle view.
Haris
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dragan
Podvezanec
Sent: Friday, August 01, 2008 8:54 AM
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Map doesn't zoom and center after
search&select
Dragan Podvezanec wrote:
> I don't know why,but after searching some object and clicking on it,
it
> gets selected, I see all properties, but Map doesn't execute zooming
and
> centering the object. It is object drown from Oracle view with
king.oracle
> provider. Could this be the problem ?
Update after inspecting my problem:
Yes, there's obviously some problem with my layer which is view from
Oracle.
I tried to export this layer to SDF, and then map centers and zooms fine
after search.
It seems like ExecuteMapAction(10) doesn't work with layer from
king.Oracle
FDO provider. Map zooms ok, but it is always centered at initial map
center.
Can someone confirm this issue? Latest MGOS here on XP and king.oracle
provider.
View this message in context:
http://www.nabble.com/Map-doesn%27t-zoom-and-center-after-search-select-
tp18754383p18769135.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
