[mapguide-users] MgInitializeWebTier causes Mapguide Server to crash
A H hizperion at hotmail.com
Sun Aug 3 08:23:43 EDT 2008
i'm using .NET env for MGOS 1.2.
my application requires user to log in and after some time, the session will
run out and user will need to login again.
on this page with a Map, after first login or normal page refresh, the page
is ok, however, after the session runs out (user session not mapguide
session, but i don't know if its both cases), and if user login, the
mgserver.exe memory used in process will rise before it crash. i tried to
comment MapGuideApi.MgInitializeWebTier(configPath); line in the code after
the page load, wait until session runs out, and relogin and the problem
doesn't occur.
is there a solution for this, or a maybe a way to see if i don't need to
initialize the config file again?
View this message in context: http://www.nabble.com/MgInitializeWebTier-causes-Mapguide-Server-to-crash-tp18798167p18798167.html
