[mapguide-users] stylize error MGOS 2.0.1
Zac Spitzer zac.spitzer at gmail.com
Mon Aug 4 08:28:01 EDT 2008
There have been quite a few fixes on the trunk for stylisation since
2.0.1, you may
find compiling off the trunk from subversion resolves some of these problems.
On Mon, Aug 4, 2008 at 9:25 PM, isca <mapguide2007 at gmail.com> wrote:
> I am encountering this problem especially when using raster layers which is a
> real problem in the MGOS software. I have no scheduled a daily job
> restarting the MapGuide service and this seems help.
> Andy Morsell wrote:
>> I have the same problem after upgrading to 2.0.1 on a Windows / IIS / .NET
>> server.  I get those messages frequently, but it seems to occur once
>> mgserver has faulted.  Once a fault occurs, all subsequent server requests
>> will then result in the failing to stylize error messages, but no real
>> clue
>> as to what caused the fault in the first place.  I use pskill and
>> psservice
>> from sysinternals.com to restart the service since it cannot be started
>> from
>> the Windows Services control panel.
>> I'm currently testing a tool that Jason Birch originally wrote to check
>> the
>> MG status to see if it will detect the failure when this occurs.  I will
>> know after next time it fails which will probably a day or so.  If it
>> works,
>> it will automatically restart the service (using the above described
>> psTools).  I'll write back as to the success once I know.
>> Andy Morsell, P.E.
>> Spatial Integrators, Inc.
>> www.SpatialGIS.com
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of ary sucaya
>> Sent: Sunday, August 03, 2008 3:59 AM
>> To: Mapguide User
>> Subject: [mapguide-users] stylize error MGOS 2.0.1
>> Hello group,
>> Since i upgraded my MGOS into version 2.0.1, i often get HTTP 500 error. I
>> checked the log file and found stylze error (attached). I couldn't restart
>> Mapguide service. It failed to stop..
>> The error layer is an ecw layer, and and an sdf layer. Is there a
>> workaround
>> for this problem?
>> Thanks
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> View this message in context: http://www.nabble.com/stylize-error-MGOS-2.0.1-tp18797661p18809467.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
