[mapguide-users] How do i load raster in MGOS 2?
Tue Aug 5 12:39:51 EDT 2008
jamesdudden wrote:
> Frank,
> I would very much like to find out more about turning a TIFF into a geoTIFF
> - simply because so far a geoTIFF is all i have working.
James,
Unfortunately, I don't know the correct coordinate system for your image, so
I just give one example.  If you wanted to assign a UTM 11 WGS84 coordinate
system you could do it like this:
gdal_translate -a_srs "+proj=utm +zone=11 +datum=WGS84" -co COMPRESS=LZW
       SavillsSSETq12sw.tif SavillsSSETq12sw_geo.tif
I didn't see any compression on your source image, but being one bit
data it would likely shrink it considerably.
The -a_srs (assign spatial reference system) switch to gdal_translate
will allow you to specify the coordinate system in quite a few different
ways.  There is some additional discussion of this in the general options
section of:
   http://www.gdal.org/gdal_utilities.html
In this case we are assuming that gdal_translate will pick up the .tfw
when reading and will incorporate the georeferencing from it into the
resulting geotiff.  If it did not exist, you could also add the
-a_ullr commandline switch to assign upper left and lower right corner
coordinates.
More detail on the gdal_translate command is available at:
   http://www.gdal.org/gdal_translate.html
More details on the GDAL GeoTIFF driver options (like COMPRESS=LZW) are
available at:
   http://www.gdal.org/frmt_gtiff.html
Note that the FWTools Shell is a regular windows command window, but with
the environment carefully setup to use the FWTools tools and dlls.  You can
"cd" to other directories, etc.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
