[mapguide-users] Same Issue with phpadmin login PHP not enabling MapGuideApi using PHPINFO - not shown in list
Rock Beans rockbeans at gmail.com
Tue Aug 5 16:20:23 EDT 2008
No this happens almost every install so thank you. I have solved many of
these with php.ini save_path tweaks and the same concept of write access.
There is another issue with PHP at times not reading the right php.ini file.
It was a registry tweak. Anyone have that tweak... I seemed to misplace it
like an idiot.
The Rock
On Mon, Jul 28, 2008 at 4:03 AM, Carl <carlshe at 163.com> wrote:
> I faced similar problem for several months. Today I open the error trace by
> set: 'display_errors = On' of php.ini and found it is because I haven't the
> enough access right to write the C:\Windows\Temp. I reset and give the
> write
> right to Users. It becomes ok.
>  I run MGOS 2 on Vista SP1.
>  Maybe I faced is not the typical. But I post here for reference.
> Rock Beans wrote:
> > http://trac.osgeo.org/mapguide/ticket/454#comment:16
> > The Rock
> > mapguide-users mailing list
> > mapguide-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> http://www.nabble.com/Same-Issue-with-phpadmin-login-PHP-not-enabling-MapGuideApi-using-PHPINFO---not-shown-in-list-tp18141274p18686540.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080805/5ebcadaa/attachment.html
