[mapguide-users] fusion - default tool selected?
Mike Adair madair at dmsolutions.ca
Wed Aug 6 16:02:30 EDT 2008
In your Fusion init method (i.e. a function registered to the
FUSION_INITIALIZED event), you can activate a widget like so:
    var mapWidget = Fusion.getMapById('mainMap');
    //enable pan widget
    mapWidget.activateWidget(Fusion.getWidgetsByType('Pan')[0]);
getWidgetsByType returns an array of widgets so the [0] in the above
statement just selects the first instance of the Pan widget.
Mike
Andrew DeMerchant wrote:
> Is there a way to make the Select tool selected by default in fusion?
> What I mean is, if I load a Fusion map there is no tool selected. So
> the user can click and click all they want, but nothing will ever
> happen until they pick the Select tool (or some other tool). In AJAX
> and DWF, the Select tool is selected by default - so as soon as the
> map loads, you can start clicking on the map to see stuff....Is there
> an easy way to do that in Fusion? Is it a matter of editing the
> templates somehow?
> Andrew
> 	*Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
