[mapguide-users] Create layer from oracle database without spatial data
Zac Spitzer zac.spitzer at gmail.com
Tue Aug 12 01:14:20 EDT 2008
is there any reason why your not just converting your data to oracle spatial?
http://download.oracle.com/docs/cd/B19306_01/appdev.102/b14255/sdo_objrelschema.htm#CBBFGHAE
On Tue, Aug 12, 2008 at 3:03 PM, 0uch <hwayuyu at yahoo.com.tw> wrote:
> Hi Max,
> Yes I have tried the way that you told before, and this is what I see after
> clicking "show table".
> http://www.nabble.com/file/p18937853/mgs.jpg
> I have no idea how to continue in this situation, so I have only one way
> that use FDO provider for Oracle.
> Are there any solution for this problem?
> T.H. Yu.
> max_samart wrote:
>> Hi,
>>       I think its not a big deal ,you can use MapGuide
>>  Studio or Mastero for creating connection using the OsGeo
>>  FDO Provider for ODBC and use DSN as oracle odbc driver
>>  causes some error or you can also try King Oracle Provider
>>  at www.sl-king.com in order to create the points using the
>>  non spatial Table,once you establish the connection and all
>>  you have to create layer using that connection and thn
>>  select the X and Y column which will create points from your
>>  oracle table.
>>  I hope it will help you out to get started !
>>  Max !
>> ----- Original Message ----
>> From: 0uch <hwayuyu at yahoo.com.tw>
>> To: mapguide-users at lists.osgeo.org
>> Sent: Thursday, August 7, 2008 10:15:38 AM
>> Subject: [mapguide-users] Create layer from oracle database without
>> spatial data
>> Hi all,
>> Is that passable to create layer from an oracle database that without
>> spatial data? (by studio 2009 or something else?)
>> If not , are there any kind of way that could build my point data (ex:
>> land-mark) on map?
>> I'll be very appreciate with any useful information
>> T.H. Yu.
>> View this message in context:
>> http://www.nabble.com/Create-layer-from-oracle-database-without-spatial-data-tp18848865p18848865.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> View this message in context: http://www.nabble.com/Create-layer-from-oracle-database-without-spatial-data-tp18848865p18937853.html
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
