[mapguide-users] Create layer from oracle database without spatial data
0uch hwayuyu at yahoo.com.tw
Tue Aug 12 01:03:59 EDT 2008
Hi Max,
Yes I have tried the way that you told before, and this is what I see after
clicking "show table".
http://www.nabble.com/file/p18937853/mgs.jpg
I have no idea how to continue in this situation, so I have only one way
that use FDO provider for Oracle.
Are there any solution for this problem?
T.H. Yu.
max_samart wrote:
> Hi,
>       I think its not a big deal ,you can use MapGuide
>  Studio or Mastero for creating connection using the OsGeo
>  FDO Provider for ODBC and use DSN as oracle odbc driver
>  causes some error or you can also try King Oracle Provider
>  at www.sl-king.com in order to create the points using the
>  non spatial Table,once you establish the connection and all
>  you have to create layer using that connection and thn
>  select the X and Y column which will create points from your
>  oracle table.
>  I hope it will help you out to get started !
>  Max !
> ----- Original Message ----
> From: 0uch <hwayuyu at yahoo.com.tw>
> To: mapguide-users at lists.osgeo.org
> Sent: Thursday, August 7, 2008 10:15:38 AM
> Subject: [mapguide-users] Create layer from oracle database without
> spatial data
> Hi all,
> Is that passable to create layer from an oracle database that without
> spatial data? (by studio 2009 or something else?)
> If not , are there any kind of way that could build my point data (ex:
> land-mark) on map?
> I'll be very appreciate with any useful information
> T.H. Yu.
> http://www.nabble.com/Create-layer-from-oracle-database-without-spatial-data-tp18848865p18848865.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://www.nabble.com/Create-layer-from-oracle-database-without-spatial-data-tp18848865p18937853.html
