[mapguide-users] Create layer from oracle database without spatial data
0uch hwayuyu at yahoo.com.tw
Fri Aug 8 00:09:40 EDT 2008
Hi Regards,
I have tried ODBC connection before.(by studio 2009)
It's succeed to connect with oracle server, but failed to show table.
there was nothing I can do and no table shows after clicking "show tables" .
After all, we found a way to solve this problem by using data that similar
with spatial data in oracle database,so we can build layer by oracle spatial
unit.
Still thanks for your response.
T.H. Yu.
Kenneth Skovhede, GEOGRAF A/S wrote:
> I'm not sure you that you can set up such a table in Studio with Oracle.
> You can create an ODBC connection to the Oracle database instead.
> On the ODBC FeatureSource setup page, you can set up tables and their
> x,y columns.
> Such a mapped table can then be used as a layer.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> 0uch skrev:
>> Hi Max ,
>> Thanks for your response,
>> I have non spatial data at all, but i got x,y values in oracle.
>> Could you tell me how to do with "use non spatial  table to create
>> points" ?
>> Thanks again.
>> T.H. Yu.
>> max_samart wrote:
>>> Hi,
>>>       I think if u have no spatial data then u have to link some spatil
>>> data with non spatial Oracle Database by using join or if u have non
>>> spatial data in oracle with x,y values then u can use that non spatial
>>> table to create points.
>>> Max !
>>> ----- Original Message ----
>>> From: 0uch <hwayuyu at yahoo.com.tw>
>>> To: mapguide-users at lists.osgeo.org
>>> Sent: Thursday, August 7, 2008 10:15:38 AM
>>> Subject: [mapguide-users] Create layer from oracle database without
>>> spatial data
>>> Hi all,
>>> Is that passable to create layer from an oracle database that without
>>> spatial data? (by studio 2009 or something else?)
>>> If not , are there any kind of way that could build my point data (ex:
>>> land-mark) on map?
>>> I'll be very appreciate with any useful information
>>> T.H. Yu.
>>> View this message in context:
>>> http://www.nabble.com/Create-layer-from-oracle-database-without-spatial-data-tp18848865p18848865.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/Create-layer-from-oracle-database-without-spatial-data-tp18848865p18884977.html
