[mapguide-users] Can't connect MySQL with MapGuide Studio 2007
Philippe Reinhart preinhart at environcorp.com
Tue Aug 12 10:58:46 EDT 2008
I have a Windows 2003 server with  MySQL 5.0.27 Community.
When I try to create a connection to this server (using the IP or the
name of the machine), I get an error message :
"An exception occurred in FDO component.
RDBMS: Access denied for user 'foo'@'my_machine' (using password: YES)"
I downloaded the last libmysql.dll and copied it into the FDO\bin
directory, as I read here and there that it solved the problem for some
persons.
I am sure of the login:password, as I checked directly in mysql command
line. This login:password works perfectly.
Ths skip-networking is on OFF, so I guess that should not be a problem.
Any idea ?
Phil
This message contains information that may be confidential, privileged or otherwise protected by law from disclosure. It is intended for the exclusive use of the Addressee(s). Unless you are the addressee or authorized agent of the addressee, you may not review, copy, distribute or disclose to anyone the message or any information contained within. If you have received this message in error, please contact the sender by electronic reply to email at environcorp.com and immediately delete all copies of the message.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20080812/4a641dd5/attachment.html
