[mapguide-users] Does it matter where you install Mapguide?
Darrin Maidlow dmaidlow at landorgis.com
Tue Aug 12 15:58:21 EDT 2008
I have a two machine thing going.  Server and web tier running on a dev
server, but the web tier is also installed on my dev machine to make for
easier debugging.
darrin
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
Sent: Tuesday, August 12, 2008 11:12 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Does it matter where you install Mapguide?
Has anyone got a two machine configuration working with 2.0?
one web tier, one server via webconfig.ini?
z
On Wed, Aug 13, 2008 at 2:47 AM, Jason Birch <Jason.Birch at nanaimo.ca> wrote:
> As mentioned, you can (and likely should) move your repository to a
> location outside of the program files directory.
> If you want to install MapGuide to an alternate location, Zac wrote up
> the instructions on his blog:
> http://tinyurl.com/668765
> This method is not officially supported, but works in my experience.
> Jason
> From: jamesdudden
> Subject: [mapguide-users] Does it matter where you install Mapguide?
> The host where i am about to install suggests installing in a different
> folder so the repositries etc will get backed up - otherwise we will
> have to
> back up the whole program files folder.
> Any advice would be appreciated
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com (My Blog)
+61 405 847 168
